Perform this procedure to view inventory attributes for vendor-specific file server information.
- Select Vendor Specific.
- Select the File Server tab.
Vendor Specific File Server Field Descriptions
Use the data in the following table to use the File Server tab.
Name |
Description |
FileServerNum |
Specifies the file server ID. |
FileServerAddressType |
Specifies the IP address type of the file server. |
FileServerAddress |
Specifies the IP address of the file server. |
